Muttley7
Muttley7 Posted at 11-18 08:42
Good thing I stumbled on this discussion thread because this is the first time I've ever heard of the SECOND edition of Dji Assistant 2 that is dedicated to Mavics. A special repeated notification from DJI about the distinction between the two versions of DJI Assistant 2 would have saved lots of people hours of stressful wasted time as they struggled repeatedly to calibrate their Mavics using the WRONG version of DJI Assistant 2.
I am now downloading the correct version of DJI ASsistant 2 for my Mavic 2 Pro but I'll never get back the 4 hours spent cumulatively in a futile effort to calibrate the drone with the WRONG version of DJI Assistant 2.
Sure enough, when I used the version of DJI Assistant 2 for Mavics, the calibration of my Mavic 2 Pro's obstacle avoidance sensors worked on the first attempt, and the "Percentage Calculation" slider scrolled smoothly from 0 to 100% in less than a minute. Prior to stumbling on this discussion thread I had wasted over 3 hours repeatedly attempting to celebrate my Mavi 12 Pro with the WRONG version of DJI Assistant 2.
If the existence of TWO DJI Assistant 2 versions had been pointed out to the very first person who lodged the complaint about a Mavic 2 Pro's calibration process being stuck at the "0% Calculation" stage, the most likely cause of that failure to calculate would have been made immediately apparent to anyone who was experiencing similar problems during their attempts to calibrate their Mavic 2 Pro.
The genius caliber engineering prowess that goes into designing DJI drones has secured the company's pole position as the perennial leading edge trend-setter of the genre, BUT the information vacuum that all too often confronts DJI customers leaves much to be desired, to put it delicately. As a footnote, my Mavic 1 Pro's procedure for obstacle sensor calibration worked without a hitch when I used the (Non-Mavic) version of DJI Assistant 2, so I had no inkling at all that my Mavic 2 Pro would require a separate dedicated edition of DJI assistant 2 for the very same sensor calibration process. |
