Disabling sensors via the c1/2 button
961 5 2018-11-1
Fraggboy
Flight distance : 81401 ft
I setup my c1 button to disable the sensors. I don’t mind the notificarion where you have to approve it.
I see all of the sensors turn red. I am in P mode and then fly into the garage between my vehicles. It still acts like they are still enabled. I have to switch into Sport mode in order to fully disable them.
Has anyone else seen this behavior?
2018-11-1
Balaes
Flight distance : 14241171 ft
Romania
the botom sensor is still active
2018-11-1
Fraggboy
Balaes Posted at 11-1 22:23
The side sensors are active also.  I took the M2 between my vehicles.  When I want to turn off the sensors, I want them completely off like when they are in Sport Mode.
2018-11-2
Mrimstad
Norway
Side sensors should not be used in p-mode anyways.
I highly doubt theyr active once you disbale them all.
Unless your in T-mode
2018-11-2
Fraggboy
Mrimstad Posted at 11-2 09:44
I understand the side sensors shouldn't be active in P-Mode, but they are (The M2P wouldn't get closer to either vehicle in my garage when I moved closer to either one (They are spaced apart 3-4 feet) in P mode.
The only time I have seen that all of the sensors are fully disabled is in S mode.
I figure this is a 'bug' and I am waiting (patiently) for DJI to respond.  Hello?!?!
2018-11-2
Mrimstad
Norway
That is wierd.
My side sensors at least disable when i disable oa this i have tried.
But now i will have to check if they are active in p-mode to.
Cheers.
Prob a bug.
2018-11-2
