P3A Video looks a little Jerky
974 4 2015-6-2
spcsaw
Not sure why but my video looks a bit jerky. Any sugestions?
2015-6-2
john.lambert4
Not a bad job, seems to be doing what it's meant to do from what I can see.  Are you referring to when you're panning that the video seems to be "jerky" or in general flying around?  I know by default the shutter speed is quite high which can create the "jerky" effect when panning.  It's hard to reduce this without attaching an ND filter unfortunately, as in the daytime at the lowest ISO setting (100) the shutter speed will be quite high.
Only suggestion would be to pan as slow as you can, small movements of the camera give better professional looking shots.  Oh and some nice RVs in that park too!
2015-6-2
spcsaw
john.lambert4@o Posted at 2015-6-3 05:20
Not a bad job, seems to be doing what it's meant to do from what I can see.  Are you referring to wh ...
I think that maybe it my friend. I had the ISO setting at 200 since it was very bright outside and default setting 8000 was way too dark.
2015-6-2
derekoneill99
My Phantom 3 is also doing this, I'll try a ND filter and see what happens
2015-6-3
