FPS_Marsh
Flight distance : 861293 ft
Hello,
I would firstly like to say I have never had an issue like this. In the past, I have had connectivity issues (resolved) but nothing to the extent you're going through. So I will do my best to help no guarantees, firstly have you got the latest firmware? the X5r and the slave controllers will both require firmware updates if it is the first time using these parts on the bird. Secondly, The second drone you bought was it the V1 or the V2? the V1 requires more than just the mounting plate to be replaced. You need to also replace the motors with the newer 3510H to support the big camera.
These are my only two thoughts on what could be causing the issue. I very much doubt its the second reason as it appears to be a connectivity issue. I would also look into the tablet/screen you are using to view the camera as it might not have the CPU power or capacity to view the transmission from the drone
Anyway, good luck with fixing your issue
