Is it possible to activate side sensors in normal flight mode?
3492 13 2018-11-4
Kune
Flight distance : 2773465 ft
Hello,
Yesterday I had a bad experience with my mavic 2.
While I was capturing some snowy mountains doing a parallax shot.....  (I was looking at the screen) My drone hit a tree.... At the begining I didn't know what happened... So I  used the find my drone function.... After a few minutes driving and  after 1 hour walking into the woods I found it... Then I checked the recorded video and the issue was it ended up hitting a tree.
The drone was flying at 120 meters high but the mountain had elevation and although my drone was at 120 meters up where it had taken off, It's altituded was cancelled out because of the mountain's elevation.
Since the mvement was a parallax, my drone hit sideways against the tree. So the side sensor would have been the solution to avoid it.
I know that in tripod mode all sensors are activated, but the drone going sideways flies very slowly.
Anyway, I was very lucky to find it. The damage was only to the shell (nose shell and a bit of the side part). And no damage to the legs.
Aside from trying to figure out how to activate the side sensors in normal mode..... As I cannot bear to see a scratch on the drone, especially in the nose shell..... and I see it is very easy to change.. just 2 screws... where can I buy this small spare part?
2018-11-4
R&L Aerial photography
Flight distance : 298100 ft
Side sensors only workin tripod mode, no way to activate then for normal flight. As far as finding a spare nose shell, no one sells them that I know of, maybe eBay?
2018-11-4
Alex B.
Flight distance : 21105262 ft
No, it’s not possible to activate the side sensors in normal flight mode!
Fly safely
Alex
2018-11-4
xagoras
Flight distance : 1357589 ft
Greece
Actually another user suggested a solution to this. If you enter Active Track all sensors are enabled. Then you just move the drone as usual without tracking anything. Haven't tried it myself, though.
2018-11-4
Fre Mo
Flight distance : 803868 ft
Good tip, thanks xagoras
2018-11-4
daishi
Flight distance : 1106325 ft
xagoras Posted at 11-4 05:06
Yep, that was me.
Here is a short test video:
2018-11-4
bikoo
Flight distance : 1534987 ft
United Arab Emirates
daishi Posted at 11-4 05:58
Yep, that was me.
Here is a short test video:https://youtu.be/Kt1IJrXdquo
Good idea
2018-11-4
Kune
Thanks all!!! Very appreciated !!! I will try for sure!!
I wonder why DJI decided not giving the option to activate it in normal mode...... I hope any admin can answer what is the reason behind...
2018-11-4
Blellow
Flight distance : 1311056 ft
What a find! Thank u!
2018-11-4
Alex B.
Personally I think that DJI limited the side sensors purely because of marketing.
To make them available all the time on mavic 3
Flysafely all and enjoy
Alex
2018-11-5
FatherXmas
Flight distance : 4058619 ft
That is way cool! I'm going to try that if the rain ever stops.
2018-11-5
El Diablo
2018-11-6
DanielVieira
Flight distance : 4633533 ft
Portugal
But if all sensors work in Active Track without tracking...DJI could make a flight mode to use all sensors that is more faster then slow-mo Tripod.
2018-11-7
Kune
Still no luck finding the nose shell yet
2018-11-18
