djiuser_72nyVLEYRH4s
Denis Strekalov Posted at 2019-2-19 22:53
To solve the network error problem 008_008 {000/0263}, the reinstallation of the file UE4PreregSetup_x64.exe helped me. It can be found in the directory created by the DJIFlightSimulatorLauncher. After this, the flight simulator successfully passes the version check and is working. In order to be able to change the installation directory at the next stage, it is necessary to run the program Fs.exe with administrator rights. Otherwise, when you try to change the installation directory, error 005_000 will appear.
This worked for me. Thank you! |
