geoffz
Flight distance : 1941322 ft
DJI Tony Posted at 11-6 16:22
Hi, thanks for the inquiry. As the optical measurement technology used by the Mavic 2 requires continuous image information, so if the shutter speed is too low the video bitrate will stop, causing the visual measurement to fail, therefore the minimum shutter speed is limited to 1/30.
We will continue to optimize the shutter threshold to ensure your flight experience, please pay attention to the firmware update. Thank you.
In the previous firmware it WAS possible to set lower shutter speeds.
However, if the user updated to the 'current' firmware it is NOT possible to lower shutter speeds.
1. So what actually took place that made it necessary for DJI to 'DOWNGRADE' the performance of the Hyperlapse flight mode?
2. Will this change and the capability to lower the shutter speed below 1/30th be made possible with future firmware updates? (or will DJI take away other user functionalities!?)
Frankly, I'm encouraged to go back to the previous firmware. |
