Cetacean
Flight distance : 2528264 ft
jpalamaro Posted at 11-7 06:50
I have scoured the menus and cannot find a brightness adjustment anywhere. I'm not the greatest at finding things but I have persevered on this as I spent a lot of money on this Pro controller for its display and while it's measurably better than my Nexus 7 on the standard controller, in bright FL sunlight it's still very difficult to fly/see, esp. in FPV. I'm about to tilt for almost $1,000 for the 7.5 Ultrabright and would rather put the money on a Mavic II Zoom LOL
I'd consider the lesser priced 5.5 inch, can't remember the designation, but not the Ultrabright but DJI asserts in its advertising it's fine in bright sunlight, but suspect it might be a warmed up version or outboard version of the display on the Pro controller I already have.
Aloha jp,
Your P4 Pro + (plus) has the same maximum brightness as my 7.85 inch CrystalSky High Brightness. The brightness levels are adjustable. There are two ways to access the brightness adjustment options.
First, the abbreviation for the brightness adjustment is called "SRE";
Second, there is a Quick Settings option, and;
Third, there is a "Settings" option.
You will have to try to find these two option versions on your own since I do not have a P4 Pro + (plus) to figure it out. But they will look related since the P4 Pro + (plus) display is the basic screen for the 5.5 inch CrystalSky. Below are two screenshots of the two settings options.
The SRE settings are circled or surrounded with yellow lines. The white dots indicate how bright the setting is. The slider is a settings option that will also change the number of dots whited.
Hope this helps!
Aloha and Drone On! |
