mehrdad486
DJI Tony Posted at 11-7 12:15
Hi, we do apologize for the troubles that it caused. I would recommend restoring factory defaults and refresh the firmware of your aircraft using the DJI Assistant 2. You can re-link the RC and aircraft after using the application, please re-calibrate the IMU and compass to see if there will be changes. You may refer to the link below for you to use it on your computer. Kindly keep us posted on the latest progress
https://www.dji.com/mavic-air/info#downloads
Thanks for your kindness . I tested it and got it right. Only when flying left Joystick automatically turn to left very slowly ... i calibrate a remote not a problem only in flight show up this problem ... refresh controller firmware 2 time but still have a problem ... I do not know what to do anymore...I need your help.. |
