Inspire 2: which firmware version do you use?
1809 9 2018-11-9
Pidge
Flight distance : 82844 ft
Belgium
V01.00.0135
V01.00.0240
V01.00.0330
V01.01.0010
V01.01.0200
V01.01.0300
V01.02.0100
V01.02.0200
V01.02.0300 beta
As the title says, what firmware do you use and why?
At this moment firmware V01.02.0200 is installed on my aircraft Inspire2 with X5S, but I am not satisfied with it.
Soon, I have a job to do with my Inspire 2 and I need the most stable firmware for this.
I have read so many articles and apparently none of them is excellent...so I'm confused.
The drone must be as stable as possible.
I would like to have your opinion on which firmware gives the most satisfaction.
Advantages and disadvantages that you have with it.
Thank you for your comments!
2018-11-9
epicjib
Flight distance : 3016060 ft
Well once you stepped into this firmware (V01.02.0100) you cant go back and 0100 and 0200 had major bugs. V01.02.0300 Beta is a game changer for me and seems to take care of the major issues. I have ran through 8 battery sets with only one compass glitch.
2018-11-9
djiuser_yGUgCAOdDMAr
V01.02.0200
2018-11-9
Matthew Dobrski
Flight distance : 1831050 ft
There's no clear indication which FW version may be best for your particular bird. There's no consistency. Most Inspires are behaving just fine right after unboxing and activation, and these should be left alone until firmware reach finally matured stage. That's my case with .0100 factory installed version.
Some drones, however, may exhibit issues (i.e. hovering stability, yaw drifts etc.) during initial tests, no matter with what FW version they're on at arrival. These should be returned immediately within established period of time, which I believe is 7 days as per DJI customer satisfaction policy.
Bottom line: if the Inspire 2 is behaving fine non arrival (with whatever camera/gimbal model), she will be fine down the road. Such conclusion is not easy to reach for a novice, but Inspire 2 is not the best bet for novices anyway.
That said, beta .0300 FW seem to be the answer for now, assuming a troubled performance with either .0100 or (worst) .0200 version.
2018-11-9
FILMART Studio
Flight distance : 267785 ft
Where to download V01.02.0300 Beta?
2018-11-10
flyingfun
Flight distance : 2551998 ft
Belgium
FILMART Studio Posted at 11-10 03:44
Where to download v01.02.300 beta?
https://forum.dji.com/thread-169577-1-1.html
send a mail  and they will set it up for you.
2018-11-10
FILMART Studio
thanks, I participate in the public beta test via e-mail
2018-11-10
engelo
Flight distance : 12311667 ft
Greece
me 2 !!! .300 tester
2018-11-10
J-Darcy
Flight distance : 847428 ft
I'm using the 01.02.0100 on mine - as I wasn't happy with the 01.02.0200 release (it was pretty unstable in the air in comparison)
2018-11-16
djiuser_2dtWgxBXs1AE
https://ovo.fyi/redtube/ https://ovo.fyi/beeg/ https://ovo.fyi/spankbang/
2019-2-4
