Uncommanded climb
2147 18 2018-11-9
Charliechan12
Flight distance : 709 ft
I experienced my second uncommanded climb today. The first was right after I bought my phantom, last month, and without stick input the drone started climbing, stopped around 70 ft and the stick, RTH inputs did nothing to bring it down. After numerous down commands it started down very fast and I was lucky to catch it before impacting the ground. The new update for aircraft and remote just came out and was installed. From a different location the bird uncommanded climbed again. All calibration including remote stick calibration is good. I talked with DJI again and will be returning this phantom. I couldn't find anyone else experiencing this problem, maybe I overlooked or searched wrong.
2018-11-9
Mark The Droner
Flight distance : 2917 ft
Sounds to me it went into RTH - probably because it lost signal or you hit RTH in error.  Note that 70 ft is close the the default height of 20 meters.
Please post the log via phantomhelp.com and somebody experienced will give an assessment on what happened:  http://www.phantomhelp.com/LogViewer/Upload/
2018-11-9
msinger
Flight distance : 228255 ft
@Charliechan12, were you able to find any helpful details in your flight log?
2018-11-12
Charliechan12
msinger Posted at 11-12 06:42
Not really, I have the .txt files and .dat files.  They show an Autoland call which I did not start. And also both files show an uncommanded climb that I don't know why. Can I upload the files here to have someone look at.
2018-11-12
Charliechan12
Charliechan12 Posted at 11-12 07:04
Sorry I see where you told me where to go earlier, going there now.
2018-11-12
msinger
If you need help reviewing your log, please post the link here after you upload the TXT file here.
2018-11-12
Charliechan12
I uploaded both files and they didn't offer for me to identify myself, what I viewed didn't show commands but did show the climbs. Are these files viewed by other members? Thanks for your help.
2018-11-12
msinger
Other members will only be able to see them if you post the links to those pages here.
2018-11-12
Charliechan12
One files is numbered YXRLVRZ7U9KBUGJYF68P, the second, 370MZ087YJTCYQSYJGGQ. First time I've done this so hopefully I'm posting the correct links. In both flights I never pressed autoland or commanded a climb. I probably reacted incorrectly after it starting climbing and trying to get it to stop and desend.  I'm new to the Phantom and it is new to me.
2018-11-12
msinger
Here are links to your logs:
http://www.phantomhelp.com/logviewer/YXRLVRZ7U9KBUGJYF68P
http://www.phantomhelp.com/logviewer/370MZ087YJTCYQSYJGGQ
2018-11-12
msinger
In both of those logs, you can see the "VPS Altitude" column is detecting something beneath your drone when it's not near the ground. Do you have any type of accessories attached near the bottom of your drone?
2018-11-12
Charliechan12
Sorry I'm asking so much, but now that I've uploaded them and referenced the numbers I just wait right.  I looked at the files and saw the autoland from P-GPS and in other file never autoland, just P-GPS and I never commanded the climb.  Almost like the remote is commanding on its own.
2018-11-12
msinger
Can you answer my question above?
2018-11-12
Charliechan12
I sent u back an answer but did it through email, which was wrong. Yes, the retailer provided a leg brace for me and it “was” attached. Based on ur question I removed it, went out for short flight and a/c responded good. I think I may have installed the brace incorrectly, he didn’t provide instructions, but do I even need it. Picture attached.[img][/img]
2018-11-12
Charliechan12
I didn’t know about VPS sensors. The 9 home built drones didn’t have those even I used DJI products on 4 of them. Stupid me. Thank you for that question.
2018-11-12
ALABAMA
Flight distance : 10442687 ft
Nice work,  msinger.
2018-11-12
msinger
That brace is really probably meant to be installed underneath the camera (to protect it). In its current location, it's blocking the downward sensors. Either slide it forward or remove it. When it's in the right position, DJI GO will not show a VPS reading like this when your drone is not near the ground:
2018-11-12
solentlife
Flight distance : 1087530 ft
Personally ... unless you really need for rough ground landing ... remove that 'brace' and go fly ... you do not need it.
Nigel
2018-11-12
Charliechan12
Yes I will leave off unless like you said, rough ground, thanks so much to everyone for the support. Now I can enjoy this bird like I wanted to. You are a “Ace”  msinger.
2018-11-12
