Suren
Flight distance : 13425892 ft
South Africa
So today i had a flight with my first battery no issues, went out just over 4km and back RTH worked great, on the second battery i was playing with the quick shot modes and once done decided to fly out a bit on sports mode, i also decided to try out the fail safe of rth on disconnect around 150 meters from me so i turned off the RC and watched the drone, after a few seconds rth engaged but instead of coming to the home point which was me it started flying away from me in the other direction, powered on RC and brought the drone back to 150 meters from me and this time tried rth by pressing and holding the rth button on the RC and it worked as it should, went back to 150 and turned off rc and rth kicked in and went the other way again so powered on and did rth on rc, when drone came down to land it was off the landing point by 2 meters or so and once landed the motors would not shut off and kept spinning and that too very fast like something was holding it back and it was trying to get away, had to shut motors off with the sticks, busy refreshing the firmware etc now and will try this again. I checked the logs and it does not show any errors
Edit: After 2 firmware refresh and recals including restarting after doing each thing the drone seems to be working like it should, even the landing is much better now and off by just a few inches as compared to before when it was off by meters
