2Blades
Flight distance : 99908 ft
Geebax Posted at 11-12 11:50
The SD card is not the problem, the Samsung card will be OK, the card has no effect whatsoever on the cache recording. Try to reduce the woirkload for the S7 by shutting down all apps that do not need to be running. The Go4 App is recource hungry, so put the phone in airplane mode as well.
Rebooted phone, put in Airplane Mode and flew. More Lags as usual, upon return and landing about 2 feet high, the GO 4 app crashed. Changed to cache to internal storage vs SD card, flight much better with maybe 2 quick lags and broght her home and landed.
The S7 Edge comes with, by default, "high performance mode" turned on. I turned it off and had a great flight with no lags and cache to SD card. Ran a second flight and there were a few short lags. It had been suggested to turn on "developer mode" and enable USB debugging. I made those changes. I took her up again and things seemd worse. Lags and artifacts so I just landed her.
App 4.3.2 (4.3.4 now available)
Aircraft 1.05.06 (no update)
RC 1.01.01
Just don't get what else to check, someone anyone suggestions, I must have missed something! |
