Raybro
Flight distance : 11099 ft
When you get the gimbal, it will come with the necessary cables as well as an anti-interference board. You should have a cable that comes out of the Phantom which will connect to the anti-interference board. On the other side of the board is a connector which connects via cable to the gimbal. On the gimbal itself, there is a mini-usb which connects to the side of the GoPro. Balancing is not necessary, although I have heard of people doing it. I have not had a problem. |
