ydanhil1
Flight distance : 433504 ft
Ukraine
Hello everyone, the mavic air remote control rotated the drone itself during takeoff or landing .. So, after 3 weeks of official "repair" I came to pick up the remote control, they immediately told me that the problem is not mechanical but software and you just need to calibrate the bullets (facepalm), I first of all did .. I connected the remote to the phone, I also looked about a miracle! everything works fine no deviations. (as it turned out later, there are deviations but not big ones). After I took the remote I flew somewhere 5 batteries and 6 problems started .. Flying between the trees, the remote simply disconnected from the drone (the red light began to flash) and the drone did not respond to the remote began to return home (the point is 10 m from the drone's position). At that time, I just stood and watched as the drone flew around the branches of trees and prayed that its point house was not China)) well, having flown between trees somewhere 2m he finally crashed into a tree and just fell down. As a result, the rear left beam is broken (everything is fine with the rest, the camera is working) ..
So what could have happened? what am I supposed to do? I look under the warranty for the case do not, I think to bring it so that they still look at the console? Why he did not sit on the ground if the point of the house was 10m and not 30+ .. here are the logs https://app.airdata.com/share/pFStCI/GENERAL in DJI GO shows that he just stood still and did not take off, although it shows that the stick (when the remote was turned off) was 100% off, there were no errors, the compass calibrated ..
I know all the nuances of flying, emergency situations, I know how to fly (before that there were 4 drones, not one had broken and none had fallen)
!!!!! and when taking off, the camera started looking left and the drone started spinning itself (apparently to align the camera), I pressed the pause button and everything became normal, after 1 minute the adventures began
sorry for my english, translated via google translator
