Lines thru the video
1443 10 2018-11-12
Jeffa1
Flight distance : 972211 ft
Hello to all friends in the DJI World can somewon answer this question please
ok i have a mavic pro and i fly with my DJI Googles everything was fine till i updated the googles firmware not not all the time while i am flying and hovering i get lines thru my screen and yes coming thru the video also not sure why or what it is.
2018-11-12
Nebuchadnezzar
Flight distance : 3428747 ft
mhh ..yes , it is visible
2018-11-12
Sky Carrier
Flight distance : 590102 ft
Strange Jeffa, definitely visible. I have the same ad home and everything upgraded to the latest versions but never saw this. Not with my MP neither with the M2P.
2018-11-12
jacksonnai
Malaysia
I have no idea with it, maybe those administrator can help you
2018-11-12
msinger
Flight distance : 228255 ft
That looks like prop shadows. Can you post a clip from one of your videos so we can see the video play?
2018-11-12
DJI Tony
Hi, sorry for the troubles that it caused. I would like to ask if you've tried to use the mobile device to see if the issue will persist without using the DJI Goggles? May I know if the image that you've provided is from our SD card? Please let us know the latest progress for further assistance. Thank you for the support.
2018-11-12
Jeffa1
DJI Tony Posted at 11-12 09:40
Hello Tony no its not with yours SD Card that came with the MP  never had any issues till i up graded the firmware on the googles do u think if i remove the firmware and re install it maybe,
its worth a shot
2018-11-12
Jeffa1
ok update on my googles today i calibrated the imu on the googles which never knew it existed on the googles can someone explain what does it to for the googles ?
2018-11-13
DJI Tony
Jeffa1 Posted at 11-12 10:30
its worth a shot
Hi, thanks for your updates. I would like to ask where did you get this images? Could you please verify if you manage to test if the issue will occur on your mobile device to isolate the issue, and see if this is only isolated on the DJI Goggles? For IMU calibration on the DJI Goggles, that would be useful if you command the aircraft using the DJI Goggles such as Head Tracking Flight or Head Tracking Gimbal that requires data of IMU. Please let us know for further assistance. Thank you for the support.
2018-11-13
Jeffa1
DJI Tony Posted at 11-13 10:11
Hi Tony haven't tested it out yet only get to fly on weekends so I will run further test this weekend and will let you know
2018-11-13
DJI Tony
Jeffa1 Posted at 11-13 14:53
Hi Jeffa, Please let us know on the latest progress and also help us to clarify on where did you get this image that you've provided.  Thank you for the support.
2018-11-14
