Red Zeppelin
Flight distance : 18286946 ft
djiuser_Kf4iPA3DtL3S Posted at 1-19 15:13
I too have a Samsung Note 8 and my problem is different - the RC thinks my phone is a charger, so it begins to charge itself off the phone's battery. The RC is not being recognized as a device by the phone.
Hi. I had the exact same issue - it's because you're using the the OTG cable at the wrong end of the chain.
I initially bought a USB Type C OTG cable to connect to the Note 8, but experienced the same charging issue you have. I stumbled on a post online stating the OTG had to be at the RC end of the chain, so I bought this instead and OTG now works flawlessly on my Note 8, using the original Samsung USB cable at the other end of the chain:
UGREEN 10396 Micro USB Adapter OTG Cable (Black)
https://www.amazon.co.uk/dp/B00LN3LQKQ/ref=cm_sw_r_cp_apa_i_fzdrCb3KRR8DE
Hope that helps |
