KenDuke
Flight distance : 50837 ft
Depending on the beeping you hear, it could be update to the controller software is needed. Or, the transmitter is in pair mode.
ON the transmitter, is the normal power on light, green, red, or blinking blue?
If Blinking Blue, its in pair mode. Goto the Aircraft, bottom left side (with camera facing you) by the sensors, you should see a red LED, right in front of that, is a small hole that is the pair button
on the aircraft. You'll need a very small pin to get this button. (I used a phone SIM card eject tool), but a small paperclip straightened out will work as well.
While the Transmitter is powered up, and blinking and beeping. Power up the aircraft. Find the reset button, and press it.
If all goes well, the transmitter will stop beeping, the blinking blue light will turn green, and you're ready for the next step.
