I was flying at 70m and the wind picked up so fast and i got a Land ASAP Warning Massage
and the drone was quite tilted in the circuler map
and i was wondering would it flip if wind is strong or if it breaks and wind blows it
This site is good to check-out wind at different altitudes.. https://www.windy.com/?-33.450,-70.667,5
But I never use it, if I feel if its too windy I just don't fly.
FulanitoFlyer Posted at 11-16 08:52
i use UAV Forecast app pretty helpful
tills KP index and wind at certain highest plus satt luck
Hi, sorry for the trouble caused. Please do not fly your drone in high or strong winds because this can flip and can cause of the crash to your drone. Please fly with caution to avoid any issue. Thank you.
DJI Natalia Posted at 11-16 10:52
nothing to say sorry about Natalia
i was just wondering nothing bad happened =)
Hi, thanks for the quick response. Glad to know that nothing bad happened. If you have further question, please don't hesitate to reach us. Thank you and have a safe flight always.
would not think that it would flip but as sslca44 said would tilt much etc. The IMU will keep it from doing that but if tilted much could shut motors off then you will get your flip or many as it falls to ground.
nmac Posted at 11-17 19:52
Thanks for your additional information. Please have a safe flight always!
You all should know that the only way a spark can flip is if it hit something or flew into a tornado. I did do some testing on mine and found out that with much wind tilted much but only so much as to keep itself in the air but got blown back. No will not tilt enough to shut down normally but with much wind as tornado nothing will be good.
nmac Posted at 11-19 00:34
Hi, thanks for your feedback. We're not encouraging our customers to fly their drone with the strong wind to test and see what will happen, or even flying it in a hazardous environment to avoid the incident. Please use the aircraft in a recommended environment for safety purposes. Thank you for the support and understanding.
