Zenmuse X5 to DJI Inspire 2
3926 14 2018-11-18
GoodmanRP
Flight distance : 4344974 ft
Poland
Hello!
I would like to ask if it is possible to mount the Zenmuse X5 lens
from OsmoPRO to DJI Inspire 2 ?
If not why?
And can something be done about it?
2018-11-18
DJI Tony
Hi, thanks for the inquiry. I would like to verify that you wanted to use the Zenmuse X5 lens to your Inspire 2? If yes, what camera are you using on your Inspire 2? Please verified to us for further assistance. Thank you for the support.
2018-11-18
GoodmanRP
Poland
Thank you very much for your quick response.
I have OsmoPRO Zenmuse X5 lens   I would like to buy Inspire 2
2018-11-19
DJI Tony
GoodmanRP Posted at 11-19 07:27
Hi, thanks for your clarification. If you wanted to use the Zenmuse X5 camera to your Inspire 2, unfortunately, the Zenmuse X5 camera is not compatible with the Inspire 2. The cameras that you could use to the Inspire 2 are Zenmuse X4S, X5S, and X7 only. Please let us know if you have other concerns. Thank you for your understanding.
2018-11-19
GoodmanRP
Poland
Thank you and I understand.
Will X5S fit OSMO?
2018-11-19
GoodmanRP
Poland
Will X5S fit OSMO?
2018-11-21
DJI Tony
GoodmanRP Posted at 11-19 09:35
Will X5S fit OSMO?
Hi, thanks for the response. Sorry that the Zenmuse X5S camera cannot be used on Osmo. The Zenmuse X5 and Zenmuse X5R  can only be used under Zenmuse X5 series to your Osmo. Please hit "Reply" to my comment if you have other concerns for me to be notified. Thank you for the support.
2018-11-21
GoodmanRP
Poland
DJI Tony Posted at 11-21 14:29
Is it to Zenmuse X5S Gimbal and Camera { https://store.dji.com/product/zenmuse-x5s-exclude-lens  }
It  fits the same lens with OsmoPRO (same lens) ???
[DJI MFT 15mm f/1.7 ASPH Prime Lens it X5S Gimbal and Camera ]
2018-11-28
DJIJAKOB
Flight distance : 740577 ft
Norway
Zenmuse X5 and X5R work on Osmo and Inspire 1. Zenmuse X5S works on Inspire 2. There's no workaround for that.
2018-11-28
GoodmanRP
Poland
DJIJAKOB Posted at 11-28 08:35
THX
2018-11-28
DJIJAKOB
Norway
GoodmanRP Posted at 11-28 08:37
THX
Yes, that will work with the Zenmuse X5S. But seems not to be available anymore, at least not in European region.
2018-11-28
GoodmanRP
Poland
DJIJAKOB Posted at 11-28 08:38
Thank you for your response. I apologize for my questions, I do not want to make a mistake.
So having the OsmoPro X5 with the camera I can only buy Zenmuse X5S Gimbal and Camera
2018-11-28
DJIJAKOB
Norway
GoodmanRP Posted at 11-28 08:45
No problem!
Yes, if you're intending to buy a camera for the Inspire 2. Your options are Zenmuse X4S, X5S or X7.
2018-11-28
GoodmanRP
Poland
DJIJAKOB Posted at 11-28 08:51
No problem!
Thank you for your comprehensive answer .
There is indeed no Single X5S in the EU
Best regards
2018-11-28
DJI Tony
GoodmanRP Posted at 11-28 08:31
Hi, thanks for your prompt reply. The lens of the Zenmuse X5  can be used to Zenmuse X5S, however, as DJIJAKOB mentioned, the Zenmuse X5 and X5R are only compatible with the Inspire 1 not on the Inspire 2. Thank you for the support.
2018-11-28
