Palmary
Hi All,
I use Mavic 2 Pro and Samsung Galaxy S8. In the camera settings as on the attacged picture, I cannot implement any settings which are listed above the Grid.
In other words, when I slide, say, Histogram slider switching it ON, it turns green (as it should) but the histogram window does not appear on the screen. Moreover, when I touch the screen outside the menu, causing it to disappear, and then start the menu again, the Histogram switch is OFF.
Same story with the rest of the settings above the Grid. Grid is working just fine as well as all the rest of the settings below.
When I connect iPhone 7 the problem disappears.
So this is clearly Samsung Galaxy S8 issue. Re-installing the app did not fix the problem.
Any thoughts and ideas how to fix the issue?
Cheers
