How can I remove this from recording everytime?
DVD Mansion
Everytime I record with the Phantom 3 Home, GPS, & ISO info also get recorded with the video I'm sure there's a setting please help me remove it, thank you
2015-6-3
lombardomal
Flight distance : 2289551 ft
Press the camera settings button. Make sure video caption in turned off
2015-6-3
kudlaty
Poland
These subtitles are not embedded into video, but overlayed from accompanying .SRT file by your video player (I assume you use VLC). You have three options - delete SRT files, disable video captions in Phantom or disable subtitles in your video player. I suggest the third option, because informations stored in SRT may be useful.
How to disable subtitles in VLC: open "Subtitle" menu -> "Sub Track" -> "Disable".
Informations stored in SRT file can be very useful. This is just a text file that you can open in Notepad. If you take a look into it, you will see a set of numbered records, like this:
114
00:01:54,000 --> 00:01:55,000
HOME(18.5904,54.3066) 2015.6.1 18:58:51
GPS(18.5928,54.3064,19) Hb:37.1 Hs:0.0
ISO:130 TV:100 EV: 0 IR:F2.8
Where:
114 - is a consecutive number of record (or just second of recording)
HOME(18.5904,54.3066) 2015.6.1 18:58:51- is a home position, current date and time (local, not UTC)
GPS(18.5928,54.3064,19) Hb:37.1 Hs:0.0 - longitude, latitude, satellites used, altitude and something undetermined yet (Hs)
ISO:130 TV:100 EV: 0 IR:F2.8 - actual ISO setting, shutter speed, exposure value and aperture (fixed, always f/2.8)
2015-6-4
DVD Mansion
Thank You guy for all the help, it was in the player, all fixed now.
Cheers
2015-6-4
