DJI App
778 1 2018-11-19
darren mark tay
Hi
In the aircraft status when turned on should the compass be highlighted as normal or compass as mine has the white box around compass when i turn on the M2, I did a compass calibration but when turned off and on again the compass had the white box around it still.. I had no warning to calibrate the compass in the app!
2018-11-19
DJI Gamora
Hi Darren, thank you for bringing this query to us. Apologies for the troubles you had recently with the app. Would it be possible to attach a screen grab of the app? If it has a white box around the "compass" that is normal. You will be prompted to calibrate the compass if the app notifies you. You may click this for more info about compass calibration. Thank you.
2018-11-19
