Nilsblix
Flight distance : 23047543 ft
DJI Tony Posted at 11-19 12:19
Hi, sorry about the uneasiness on the firmware update of your Inspire 2. You mean you have to directly connect your Inspire 2 without the camera to your iOS device to upgrade the firmware of your aircraft? Did you check if the aircraft is on PC mode when updating the firmware using the DJI Assistant 2? Have you tried to factory reset the aircraft and try to update the firmware again? You have to use the camera while doing the firmware update so that the Zenmuse X5S will be updated as well. Please let us know on the latest progress. Thank you for the support.
Thank you for your answer.
Yes I am aware of that I2 have to be in PC mode and have done that. And yes I have to directly connect my Inspire 2 to a iOs device to get it updated - in two processes first without the camera - then with the camera to get it updated. I have had a lot of DJI products for several years so this kind of workaround is not critical for me, but I simply think it is weird.
I have not done a factory reset - I could do that but I have hesitated as I would loose my settings. Can you think of a reason for this situation ? |
