iPad mini/iOS offline maps.
638 5 2018-11-19
djiuser_6skJaeLno6Ca
Flight distance : 21316 ft
Hello, just got iPad mini and new to iOS format. I have downloaded the Go4 app successfully but can not find an option to download my local area in maps for offline use. I seem to recall that being an options in my Android phone. Could anyone advise please. Kind regards in anticipation.
2018-11-19
A CW
Flight distance : 13877205 ft
Ensure you are connected to WiFi on the device you are using - connect it to the drone and scan the area in maps after GPS is connected.
2018-11-19
A CW Posted at 11-19 13:02
Ok thanks so I need to connect the drone to do that. Thanks for your help.
2018-11-19
DJI Tony
Hi, thanks for your inquiry. You may need to connect your mobile device to your home wi-fi first then enable cache map in the background from DJI GO app. It's under the general settings of the app then you could explore the place you want to fly at using the map. Please let us know if you will still encounter a problem. Thank you for the support.
2018-11-19
Nidge
DJI Tony Posted at 11-19 13:41
Can you be more specific?
I’m running iOS App version 4.3.4 on 6th Gen iPad, and I don’t see a “Cache Map” option in General Settings.
2018-11-20
A CW
djiuser_6skJaeLno6Ca Posted at 11-19 13:33
I do for the best results
2018-11-20
