Aardvark
Flight distance : 384432 ft
That could well be the case, if DJI Go 4 is reporting 02.00.0700 then that is what is installed on the P4, as DJI Go 4 interrogates the P4 for the information. It may be likely that the older Assistant 2 is not able to correctly report this on screen. Install latest Assistant 2, and see what it says when P4 is plugged into computer.
If no change then I would attempt a 'refresh' and a 'factory reset' using latest Assistant 2.
