P4P 2.0 No 5.8 Ghz?
1166 14 2018-11-20
Flyer001
Flight distance : 2710571 ft
I’ve discovered the source of my noimage transmission woes has been that my new P4P 2 doesn’t seem to be connecting on 5.8 ghz.   If I force it to 2.4 ghz rather than dual mode everything works fine, but switching To 5.8 causes the noimage transmission issues.   I’ve reminded the remote and tried with multiple devices, but with the same result.   Anyone else seen this and have a suggestion for getting 5.8 to work?
    Thanks!
2018-11-20
DJI Natalia
Hi there, we're sorry for the inconvenience caused. Can you please try to refresh the firmware of the aircraft via DJI Assitant 2? And try to do Restore Factory Default with the RC. If the issue still persists, I suggest you send back both the aircraft and the remote for analysis. You may contact our support for a further help at http://www.dji.com/support. Should you have further question, please let me know. Thank you.
2018-11-20
Airport Dog
Flight distance : 1164226 ft
5.8 Never was an option for my V2.0, grayed out. I got the same response to refresh and restart, nothing. It's in Cerritos CA as we speak for repair. My only resolve.
2018-11-21
DJI Tony
Airport Dog Posted at 11-21 07:17
Hi, sorry to know that you're product ended up sending it to our repair facility. However, if the troubleshooting steps were exhausted then I'm afraid the sending the unit would be the best option for our team to evaluate the unit further. Please let us know if you have other assistance. Thank you for the support.
2018-11-22
Flyer001
Refreshing the firmware on the drone and controller and relinking the drone and controller had no effect, so I sent it in for service.
2018-11-26
Airport Dog
Flyer001 Posted at 11-26 13:13
Sorry you did that.
2018-11-27
Anthony8858
Flight distance : 9711 ft
I went back and revisited this issue..At this time, I only showed 2.4ghz as the OP.
I also found the solution:
Go to remote setting and re-link the remote controller.
The remote will blink while it waits for you to hit to link button on the P4P.
Doing this updated my Go4 app and 5.8 is now an option
2018-11-27
Flyer001
Mine always showed 5.8, and it was selectable, but selecting it would result in ‘no transmission’
2018-11-27
Huytd1
Vietnam
https://bit.ly/2KBjyYk
2018-11-27
SPIKE_151
Flight distance : 69767 ft
Mine comes and goes depending on the amount of wifi interference on 5.8 which is faily bad at the moment.
2018-11-29
SPIKE_151
2018-11-29
Flyer001
SPIKE_151 Posted at 11-29 06:58
Looks like mine turned out to be a bad camera board / flat flex cable.   As it was still under the original 15 day warranty DJI replaced them and shipped it back for free.
2018-12-5
Filip Kyzek
Czechia
5.8 GH for me is useless. All the time I am using 2.4 GH because I can fly a lot further and have stronger signal.
2018-12-30
linhkienstore
Vietnam
In my country they call this device Flycam and usually use it at 2.4 gh to be able to receive a more stable signal, and not all devices can use 5.8 gh floor, thank the article And your comment I found it really helpful!
2019-7-14
linhkienstore
Vietnam
https://bom.to/gpV2t
2019-7-15
