Beginners Mode Question
946 5 2018-11-20
Oracle008
Flight distance : 4744 ft
Newbie question...
In beginners mode, as i understand there's a max altitude(98ft).
If I set my RTH Altitude to let's say 200FT, will it follow the 200FT even in beginners mode? Will the set RTH Alititude override the beginners mode limitation?
Thank you.
2018-11-20
HedsIc
Flight distance : 478757 ft
Can you go far enough in beginner mode for RTH to activate? You have to be so far away from the homepoint for RTH to work and I beleive beginner mode keeps you withing that distance so it would probably just land (whtout ascending) where it is.. I could be wrong though since I can't remember what the max distance allowed is in beginner mode.
2018-11-20
DJI Tony
Hi, thanks for the inquiry. If your drone is under beginner mode, then the distance and height will be limited causing the drone not to reach the preferred RTH settings although we set it higher than beginner mode. I would recommend setting the RTH altitude higher than any objects below when flying in a specific location to avoid the incident. Thank you for the support.
2018-11-20
hallmark007
Flight distance : 10017858 ft
Sweden
98 ft will be your maximum, so try to insure no obstacles higher than this, to get familiar with RTH try it once your outside 20 metres from home hit the button see how it works, you can cancel at anytime just hit the X button and confirm you want to cancel, you will find it very easy and quick to go from beginner mode to normal modes but first couple of flights it will help.
Good Luck.
2018-11-20
A CW
Flight distance : 14312858 ft
It's fenced at 30m in beginner mode in all directions and you will not be able to take off until there is a GPS lock and home point recorded on the map.
2018-11-20
Oracle008
Thank you all. I'm planning to do my first flight after the thanksgiving week. right i'm trying to learn all i need to know.
2018-11-20
