Phantom 4 camera
523 4 2018-11-20
pSQZ3STACEV8
Indonesia
Hi,.. I got two P4, one had an broken camera the other are good, can I switch the camera...?thanks all
2018-11-20
Ryan Olivas
Why do want to switch the camera though?
2018-11-20
Geebax
If the two aircraft are of the same type, then yes, you can swap the cameras over.
2018-11-20
A CW
Flight distance : 14177772 ft
Yes you can  - as long as they are both the same P4 model.
2018-11-21
DJI Tony
Hi, thanks for the inquiry. The damage drone can be sent to our facility so that our team could be fixed and use the warranty if any case that it will be covered. Since fixing the drone is not recommended due to warranty avoidance. If you need to contact our support, you may refer to the link below. Thank you for the support.
www.dji.com/support
2018-11-21
