Cetacean
Flight distance : 2528264 ft
DallasDroneGuy Posted at 2-13 12:43
I am not sure I understand your comment. The warning will go away but the OP still will be limited correct, except now limited to 120m. So how is that related to you flying at 1600+ in your location? I ask because I need to shoot around tall buildings. Totally legal to go up to 400 feet above the roof as long as I am within 400 feet laterally of the building. So 500 foot building, I can legally go 900 feet AGL. But I am limited to 393' which makes me worry that auto RTH won't even climb over the buildings if necessary. Any insight that may help here? Thanks in advance.
Aloha DDG,
One of the RTH options is to backtrack along the path that got you to the disconnect. If used, this will return you into a location with communication between the Phantom and the RC without having to go over the tower. (To me that is the more important question.)
To answer the other question, 500 meters is the maximum computer limited altitude for DJI quadcopters. That allows the Phantom to fly up to a maximum of 1640 feet above the device on the remote controller.
The RC has no GPS but the Phantom and device do. If the device does not have GPS, there are certain Intelligent Flight Modes that will not work. Setting MAX Altitude to 500 meters is how you will be able to get up to 900 feet to inspect your tower and if you went over the top to get to the other side and there you lost your signal, the RTH will still be able to backtrack over the top to get home or at least get the signal again.
IMHO, Edward's problem was not having input the right numbers. 122 meters is an alert to the DJI software to issue the warning. It is artificial intelligence after all and takes actions in response to input. If he sets the max altitude to 120 meters, the message will go away.
Hope this helps!
Aloha and Drone On! |
