DanielVieira
Flight distance : 4633533 ft
Portugal
El Diablo Posted at 11-22 23:23
You are kind of obsessed with the Moire thing... Moire only happens when shooting repetitive patterns that surpass the resolution of the sensor and at specific angles. if you are going to keep shooting brick houses midday, perhaps you should consider a different drone. You can partially reduce Moire in post but not elimimnate it completely. As I said before, VERY expensive DSLR cameras with lenses that cost more than the M2P have Moire.
FYI, the side sensors aren't the same as the front or rear sensors, from my understanding they cannot operate at higher speeds than the auto modes. Therefore, I don't believe this could be fixed through fw but perhaps in an M3P.
About the sensors, they can and they work....just go to Active Track and use them without track anything |
