djiuser_8ovV1BpngaaL
Flight distance : 158205 ft
So unlike a camera fixed to a motorized slider that can be extremely precise, a drone based hyper-lapse is hovering and affected by wind which, if the distance between two photos is too close together, will result in an extremely jittery hyperlapse... even if the difference was 1/4 inch in altitude. DJIs solution apparently was to increase the distance the drone must move in order to get something usable. If you want to condense 15min of real-time action into something like 10sec, you have to move the drone almost half a kilometer. There’s a min speed in the other hyperlapse modes too - for instance, if you select circle, although you can set duration and speed, if the radius of your circle is too short it will keep circling until the duration is reached. (As opposed to dividing a single lap into 250 equally spaced photos) Does this make sense? So unfortunately if you want longer final videos, you need to increase your distance. |
