Ronin s
1993 9 2018-11-23
djiuser_3GK1Lu89DT2f
Hi I’m wondering if the Sony E PZ 16-50mm lens is  compatible with the ronin s focus wheel
2018-11-23
DJI Natalia
Hi there, I appreciate your time bringing this query to us. However, the Sony E PZ 16-0mm lens is not yet compatible with the Ronin-S Focus Wheel. Please see the attached image below for the listed lens that is compatible. Should you have further question, please let us know. Thank you.
2018-11-23
crasyjoey98
can I also ask what is the difference between the two MCC-Multi cables on your website I know ones for Sony but what is the actual difference in the two
2018-11-23
crasyjoey98 Posted at 11-23 13:19
Hi there, the port is different, different cameras connect to Ronin-S with different cables, MCC-mini cable is compatible with cameras like Canon 5D MK III and other cameras in the future.
2018-11-27
crasyjoey98
DJI Mindy Posted at 11-27 22:19
Hi after my MCC Multi cable arrived today. I decided to see if the Sony E 3.5-5.6/PZ 16-50mm oss lens works with the focus wheel as a zoom and I can confirm it works perfectly fine with a nice smooth zoom Just like my Sony 18-105G lens
2018-11-28
crasyjoey98 Posted at 11-28 14:09
Glad to know that and thanks for sharing, hope you have a great time with Ronin-S.
2018-11-29
crasyjoey98
DJI Natalia Posted at 11-23 11:07
[view_image]
Sony E pz 16-50mm lens is  compatible as ive tested it today as on your camera compatibility list it says it isn’t. Hopefully you can add it to your list after you’ve confirmed it.
2018-11-29
DJI Natalia
crasyjoey98 Posted at 11-29 07:04
Hi there. Thanks for the update. I'll forward this information to our R&D department for further clarification. Thanks for your support.
2018-11-30
fans9c812494
DJI Mindy Posted at 11-29 02:28
Hi I have a Sony A6300 with a Sony 10-18 lens. I bought the cable I started the Ronin before the camera and it worked. Then later on I tried again and I can’t get it to work. So now it’s been 3 days it doesn’t work. Any ideas? Thank you
2018-12-29
fans9c812494 Posted at 12-29 12:38
Hi there, sorry to hear that, may I have more details of 'can't get it to work'? Please power on the Ronin-S first and then the camera.
2018-12-30
