Cetacean
Flight distance : 2271506 ft
Aloha DT,
The "Jittery" video is due to panning too fast for the framerate. Using a minimum of 30 frames per second and slowing down your PAN (YAW movement) will usually reduce or get rid of that problem. The human eye has a "flicker rate" of about 25 frames per second so using 30 or even 60 fps provides a "cushion" for the lateral movement in a PAN. (For some reason, Europeans like the 24 fps setting and the jittery effect or maybe it forces them to PAN really slow.)
Many drone videographers in the US use the 4K 30fps setting and slow down their PANs so their footage provides better flexibility in post. (Using 60 fps will also help but requires more work in post to match smoothness with the slow motion effect.) The smoother PANs are much easier on the viewing audience, especially us old guys. I like to see the details of our high definition videos and some of these fast PANs can get down right irritating. If the PAN is slow, the viewer can see the beautiful details as the camera rotates.
There are also a number of settings that help smooth out PANs, especially EXP. PAN, and the flight equivalent YAW actions, probably have the most settings available in the DJI GO and DJI GO 4 apps. Here is a link to an online manual by DJI Grace that really helps you go through the DJI GO 4 app on your computer so you are not draining your batteries;
https://forum.dji.com/forum.php?mod=viewthread&tid=118397
You can usually find it in the column to the right of the Phantom option of the Forum. Grace used the Mavic platform for the manual but there is enough similarity that it is useful for all DJI product users.
Since you are a pilot, you can easily think about many of these settings as something related to trim on a plane, but a lot of them are more of an algorithm between input and output on the stick. Computer gamers have a lot of that with their joysticks and gamepads, so if you also play computer games, these settings, especially EXP, are a slam dunk.
Do be aware that you will want to do one setting at a time (start with EXP) to see if the effect is what you are looking for. That way if you screw something up (like we all do), it is easier to fix. If you find a setting that really works, you might want to write down a note or list of settings that work so if you should have to do a reset of default settings, it is easier to get back the settings that work. You will eventually find that what works for you is probably a specific combination of settings.
Hope this helps!
Aloha and Drone On! |
