Mark The Droner
Flight distance : 2917 ft
I was looking at the underground weather data for Winnipeg. The graphic seems to say wind was from the South at around 15 mph.
https://www.wunderground.com/his ... =22&reqdb.wmo=71579
That's surface winds. Winds aloft would be stronger.
Am I reading it wrong? I agree your AC speed within the log seems to show you have winds from the north, not the south. I apparently read the graphic wrong. The text chart says wind from the North. My bad.
Still, with dozens of compass, GPS, IMU, and wind speed warnings, I don't know how you can justify flying away from homepoint at top speed on a waning battery. A bad compass, GPS, IMU - any one of those could confuse your AC as far as its ability to find home. You knew there was a disconnection risk, and you kept flying further out. And the north wind is even worse news, because there's really no way to guess where the AC might be. With a tail wind, I think it should have made it home if everything was working correctly, but clearly you had multiple issues and you were repeatedly warned about them and you repeatedly ignored them. So who knows what direction the AC went in its quest to find home. Yeah, you could call this a flyaway if you wanted, but it's a pilot-induced fly away.
Bottom line: I don't think it's possible to find your AC with the data we have here. Maybe somebody will find it your phone number on it or you have data on your SD card which will help the finder locate you?
Sorry for your loss.
