DJI Gamora
Ulysses Posted at 11-26 04:28
Thanks! That I knew. My concern is mostly about the health of the motors, if Auto Tune would be somehow bad or good for them if performed frequently (you know, that noise most of times doesnt mean something good in electronics. Hopefully not the case here).
I get myself doing it more than often. Even though I'm using the same setup from a previous shoot. In parts for a peace of mind. And Im using a relatively heavy setup, a Blackmagic Cinema Camera (all metal, heavy) with a Sigma 18-35 (mostly metal, heavy), plus filters. Sometimes I even put an anamorphic adapter in front of it and it balances great. A battery brick and an external monitor are mounted to the side with a chesseplate adaptation I made. But its very different than a relatively light DSLR. So it always get me wondering if Im not forcing the motors doing Auto Tune and should do that only when really necessary. Dont know what happens under the hood.
Hi Ulysses, in this case, if you are using the same set-up with your Ronin-S with your previous shoots, you don't have to use the Auto-tune to calibrate. Auto-tune comes in whenever you switch cameras, lens, or accessories that may differ to the set-up you had previously. Kindly take note also of the maximum payload capacity with the Ronin-S which we tested up to 3.6 kg (8 lbs.) while maintaining optimal performance and apparently, your current set-up is still within the payload capacity. Hope this clarifies your concern about Auto-tune Ulysses. We appreciate your support with DJI. Cheers! |
