Red lights flashing. No response from Ronin S after firmware upgrade
7474 7 2018-11-26
jonathangoff
Flight distance : 144915 ft
Israel
I am also having an issue with the firmware upgrade. I tried updating to the latest firmware (from the original shipped firmware) using DJI Pro Assistant for Ronin v2. The update failed, gave me an error message and told me to restart the Ronin. Before the restart, I see the 1, 2, and 3 lights and double flashing red. I restarted the unit and as soon as I power the battery back all three lights start flashing red in a double pattern. Pressing the power button on the gimbal does nothing.
I need the Ronin S for a very important shoot today. What can I do to gain control of my Ronin S again?
This is the error I received.
2018-11-26
Chris_E
Flight distance : 243474 ft
Downgrade to the prior version. Worked for me.
2018-11-27
jonathangoff
Israel
Good thought, but the program is no longer recognizing the Ronin S, so I can't downgrade. Ugh
2018-11-27
fansbc3ebbbe
Flight distance : 1827 ft
Did you find a solution?
2019-10-31
Tilburym
Any luck with this? I’m having the same issue
2019-11-19
BenHemmer
Any Solutions??? litterally just unboxed Ronin S, installed, balanced, started updating firmwares, got the the one before last, then my ronin S disconnected from computer and app. The gimbal now has 3 blinking red lights. Doesn't respond to anything. Can't upgrade or downgrade firmware because can't connect to laptop or phone. Please help.
2020-7-8
jonathangoff
Israel
Unfortunately, the only way I could get it fixed was by taking it in to the store I purchased it at and they had to work on it (not sure what they did). Now I'm scared to upgrade again. ha ha
2020-7-8
djiuser_50qqDIfXAE5J
South Africa
Hello, Guys I Trust You are all Well.
I have a Problem. My Gimbal doesn't Connect to the PC at all, It only Charges.
Another ISSUE, my Motors aren't Responding
2021-11-21
