Hi guys!
recently just received my 2 axis master wheels for my DJI Ronin 2 set up.
I have been building it and figuring out ways to mount diff systems on the ronin and master wheels so I have my optimal setup.
I have found a problem with the DJI Pro Wireless Receiver. This receiver is recommended for optimal transmission to the master wheels from the Ronin 2.
unfortunately, it seems that this receiver CAN ONLY be powered and used off the 2 6 pin power ports on the pan motor of the gimbal!! just those 2!!
this means that you have to find a suitable place to place the receiver - nowhere really to mount properly and securely. it really limits your mounting points and you still have a cable and antenna to worry about.
it seems like a firmware fail as it is best to power that receiver from anywhere on the rig - and mounting is crucial if the rig has to fly or be put thru some high-speed environments.
can anyone at DJI please help or pass this on for the next firmware set of issues?
thank you!
(pics attached)
