Ronin S 12V/2A pinout // diy can-bus to d-tap mod cable
9152 11 2018-11-27
Flo the Pirate
Austria
Hi ,
if you want to use the ronin S with the old Dji Focus or power your camera you will want to use the two 12V/2A can ports. I read in some other thread
that the pin out is 1:+12V , 2:-12V so it seams easy and straight forward to make your own cable. I my case I wanted a can bus to d-tap so I can power
the old Dji Focus and the Blackmagic Pocket 4k camera.
So I ordered this Dji cable : https://store.dji.com/de/product ... or-ronin-mx-srw-60g and cut it in half to get the can bus plugs and I ordered
a female d-tap plug https://www.amazon.com/Vellcon-R ... ywords=d-tap+female . Total cost about 20€ for two canbus to d-tap cables.
So this is what´s gonna save you some time as you can´t know which pin is represented by what cable:
red is 12V+ , blue and gray/white are for data - and then there are a bunch of unshielded blank cables you should all twist togeather for your 12V- !
hope this works for you and saves some time
can bus cable
can bus cable
almost finished
almost finished
finished can to d-tap
2018-11-27
dopey-tree
Flight distance : 6716467 ft
Awesome just what I was looking for!
2018-12-15
Flo the Pirate
Austria
dopey-tree Posted at 12-15 08:32
;) I was already wondering if I was the only one looking to do this ....
2018-12-15
AllAirStep
Portugal
Flo the Pirate Posted at 12-15 12:22
Heyy, I bet you are not!  I am trying to do the same with the ronin s to power the bmpcc4k and the tilta nucleos motor
Was wondering if your setup is running fine!
Hope to hear from you, thanks in advance
2018-12-18
Flo the Pirate
Austria
AllAirStep Posted at 12-18 13:32
All works fine ... if you run into problems powering from one can bus try to take power from the second - I ran into this problem with a teradek
2018-12-19
djiuser_Su4C0YavnHWf
Hello
excuse my English
I'd like to feed the pocket 4k, do you have any idea as far as it could feed ronin s and pocket?
2018-12-20
fans1ae40bcc
I think this cable should work too, a bit cheaper and you don't have to cut and throw away a connector .. It's meant for the MX but as far as I understood, can bus connection are the same as the S
Ronin-MX RSS power cable :
2019-1-14
Kwan
I modified this long ago for Tilta Nucleus M, may help you
2019-1-14
Flo the Pirate
Austria
fans1ae40bcc Posted at 1-14 01:16
[view_image]
this should work as well ! But u don´t have to throw away a connector ... just make two units for those two power outlets .... at one point you will need them eg focus motor or teradek ..
2019-2-8
Flo the Pirate
Austria
Kwan Posted at 1-14 14:13
https://www.youtube.com/watch?v=EWu6WPumV4s
sweet setup !
2019-2-8
Flo the Pirate
Austria
sweet setup !
2019-2-8
djiuser_Q4fMdo7akbqH
Hey, can you make a more detailed video on how you made the 7pin to Ronin/S cable?
2019-12-3
