Camera has crazy lines on the video recorded and when on snapshot
12Next >
28060 63 2018-12-1
Mizee
Just got the Tello today, charged it before flight then after turning it on and connecting to my Note 9 i get the issues attached. The recorded video looks very weird with lines but worst of all is when on snapshot mode, you cant even see anything but crazy colors. Is this a bad unit or is there a settings to fix it?
Video recorded
Video recorded
2018-12-1
jacksonnai
Malaysia
Try to uninstall the app and reinstall it
If it still not working then you might need to contact their customer support
2018-12-1
jacksonnai
Malaysia
Btw welcome to the forum!
2018-12-1
RYZE
Super Moderator
Hey Mizee, sorry for this unpleasant experience. May I know if you have you ever tried another mobile device? It looks more like the compatible issue between Note 9 and Tello APP. And we sincere sorry that there isn't a setting to fix it. In regard to it, could you please offer screenshots of the version of the mobile phone, of APP version and firmware version below for further analysis? Thanks a lot in advance.
2018-12-2
Mizee
RYZE Posted at 12-2 01:05
Just tried it on an iphone 6s and it works, attached is the screenshot of the app and firmware. Are you guys going to come up with a newer update for the note 9 soon? Im suprised the note has been out for a few months already and no patch of yet? Let me know. Thank you!
2018-12-2
RYZE
Super Moderator
Mizee Posted at 12-2 11:59
Glad to know that you iphone 6s works. In regard to your concern, we first apology that there is no relative notice if note 9 would be on the compatilbe list at the time being. However, I would give all these information to the R&D department. Meanwhile support for additional devices available as testing and development would continue. Sorry for the inconvenience caused.
2018-12-2
Mizee
RYZE Posted at 12-2 17:43
Problem is its not my iphone 6s. We only have Note9s in the house. So I hope you guys come out with the patch soon!!!
2018-12-2
RYZE
Super Moderator
Mizee Posted at 12-2 20:42
Thanks for the quick reply, don't worry that I pretty understand your problem. Sincerely apology that Note 9 is not on the recommended device list yet and we can't ensure its compatibility. I already feedbacked all these info to engineer to look into it. If possible, we would like to suggest you use the compatible device.
For your reference, here is the link about the recommended device list : https://www.ryzerobotics.com/tello/downloads
2018-12-2
fans969d203d
Brazil
my tello also has the same problem in video mode. Tested on ipad 2 mini, ipad air and samsung galaxy s8. disappointment...
2018-12-17
RYZE
Super Moderator
fans969d203d Posted at 12-17 17:01
That must have been frustrating for you, very sorry about it. In regard to iPad 2 mini, iPad air, if the firmware version of Tello is latest, please kindly extend your patience, reset assure that we would push forward new APP to correct it. Also, sorry that Samsung galaxy s8 is not on the recommended list and can't ensure its compatibility.
2018-12-17
fans969d203d
Brazil
RYZE Posted at 12-17 18:16
When you switch to fast flight mode, the video image is normal.
2018-12-18
djiuser_E7ZqqabDJhDQ
Could be your app.
2018-12-19
m1n1s
Flight distance : 319915 ft
generally most androids struggle with DJI and RYZE stuff , iOS just seems to work seamlessly
2018-12-24
Juliana Pimentel Panisson
Brazil
Hi, I had the same issue in Brazil and I have a note 9 also. Tried in S7 and worked. I'm very frustrated as I brought to take pictures of my vacation and now I can't.
2018-12-26
Brazil
fans969d203d Posted at 12-18 00:53
When I switch to video mode, the quality is poor and black and write. Is that something I need to set in the camera of my note9?
2018-12-26
Keego63
Flight distance : 10082 ft
I have a Note 9 and have no problems with the video or photos showing on the phone screen.
Check your permissions for the tello.
This is what I see in my Gallery.
My Gallery
My Gallery
Tello Permissions
Tello Permissions
2018-12-26
RYZE
Super Moderator
Keego63 Posted at 12-26 06:22
Nice sharing!
2018-12-27
Brazil
[Image]
Permissions are ok in my note 9 and the lines are still showing up. Green lines and videos in Black and Write.
2018-12-28
Keego63
Juliana Pimentel Panisson Posted at 12-28 02:54
Have you updated to the latest drone Firmware and the latest android application.
2018-12-28
RYZE
Super Moderator
Please kindly check if it persists after upgrading to the latest firmware version  - 01.04.78.01.
If persists, you might also try steps below :
1. Power it off
2. Hold the power button for about 5-8s until the solid green led goes off  [ Please release it once the green led goes off ]
3. Wait until a flashing red led goes on automatically.
4. Connect its wifi , redo firmware upgrade then.
2018-12-28
Mathew Makarowski
I just recieved my Tello, and when I turned it on had the exact same screen with green lines and everything. I'm also using a note 9. I'm not using another phone to fly this, I don't have one and I would like to know how to fix this problem
2019-1-2
RYZE
Super Moderator
Well received Mathew, sincerely sorry for this unpleasant experience. Per it, may I know if it works before? Does this issue occur right after updating the Android version, or the APP version, or the aircraft firmware version? For further analysis, Could you kindly provide the info below :
1) The model number of your mobile phone.
2) Screenshots of the system version of the mobile device.
3) Screenshots of APP version and firmware version.
2019-1-3
LucasCasa
Argentina
Hello, I'm having the same issue with a Moto G5S plus and a moto G5. the firmware of the tello is 01.04.78.01
2019-1-15
RYZE
Super Moderator
LucasCasa Posted at 1-15 16:55
Sincerely sorry for this Lucas, for further analysis. As usual, may I know if the two devices worked before? Does this issue occur right after updating the Android version, or the APP version, or the aircraft firmware version? For further analysis, Could you kindly provide the info below :
1) Screenshots of the system version of the mobile device.
2) Screenshots of APP version
2019-1-15
LucasCasa
Argentina
Hello, I just bought it and it never worked. I attach the app and system info
Thanks.
2019-1-16
RYZE
Super Moderator
LucasCasa Posted at 1-16 03:06
[view_image]
[view_image]
Dear Lucas, your valuable info would be appreciated.  We will also report your case to the R&D department. For now, It is recommended to use the Tello app on a compatible Android device.
Sincerely sorry for the inconvenience caused.
2019-1-16
DanLeclair
Hello,  I am having the same issues with green lines.  I am using a Moto G5 plus and it worked well for almost a year until I upgraded to Android 8.1.0.  In reading this thread I see phones that use Android 8 & 9 are having the same issues.  I tried to uninstall and reinstall the Tello App and it did not fix the issue.  I believe that Ryze needs to fix the App to work with phones that use the Android 8 & 9 versions of the operating system.
2019-1-16
NOLAChuck
I too am having this problem.  I have a Moto G5 Plus running Android 8.1.  I have the latest Firmware unless a new version has been created in the last couple of weeks. My problems started in January. I tried deleting and reinstalling the app and that did not work.  This was my first and is my favourite drone. I hope you have a fix for this problem besides "get another phone."
2019-2-6
NOLAChuck
DanLeclair Posted at 1-16 22:10
I am having the same issue. Hope they fix it.
2019-2-6
RYZE
Super Moderator
NOLAChuck Posted at 2-6 05:43
I too am having this problem.  I have a Moto G5 Plus running Android 8.1.  I have the latest Firmware unless a new version has been created in the last couple of weeks. My problems started in January. I tried deleting and reinstalling the app and that did not work.  This was my first and is my favourite drone. I hope you have a fix for this problem besides "get another phone."   [view_image]
Dear NolaChuck, sincerely sorry for this. We are aware of this case and would deliver your info to an engineer and see what they think about it.Have a wonderful Flyday ahead!
2019-2-6
RYZE
Super Moderator
Sorry for the miss DanLeclair, that would well receive ed.
Thanks for your valuable feedback. I would feedback to engineer for further inspection. Warmly reminded there would be some delay due to Chinese spring festival. Thanks.
2019-2-7
murrintjc
I am experiencing the same issue on my Galaxy J3 Eclipse smart phone.  But when I run on other devices I have... All is good.
The Galaxy J3 Eclipse is running Android version 8.1.0
Samsung Experience Version: 9.5
I can get you folks other information if you think will benefit resolving matter / for future patches, etc.
2019-2-12
RYZE
Super Moderator
murrintjc Posted at 2-12 05:47
Appreciate your kindness murrintjc,  we are pretty sorry for this. If convenience, can you offer the snap of firmware version and APP version of the drone, as well as the green screen. Besides, do you suffer this issue all the way or does it occurs after upgrading or else?  Thanks.
2019-2-13
Blake Cremeans
Same issue on my Moto Z3. All firmware is up to date. App has been uninstalled/reinstalled twice and updated each time. Tello has also been updated.
Bought this yesterday (2/15/19) and did it out of the box.
Photo mode shows only green lines in live view (but the photos themselves are fine. Video feed has green lines. The recorded video resembles the video feed.
2019-2-16
RYZE
Super Moderator
Blake Cremeans Posted at 2-16 13:59
Thanks, Blake,we respectfully recommend you using the Tello app on a compatible Android device. We will also report your case to the R&D department. Sorry for the inconvenience caused.
2019-2-16
Humberto Beltrão
Brazil
I've just got my Tello and the same issue (green lines) persists on my Android Moto G5S. It's so frustrating. :/
2019-3-16
RYZE
Super Moderator
We sincerely sorry for this issue Humberto. In reference to the green screen, Please kindly use another compatible device for the moment. Meanwhile, that would be appreciated if you can provide the following info at your earliest convenience, which would be reported to the R&D department and try to solve it. Sorry for the inconvenience caused.
- After what operations this issue occurred.
- Screenshots of firmware version & APP version
- Screenshots of mobile phone version.
Click here to find out the recommended devices: https://www.ryzerobotics.com/tello/downloads
2019-3-16
djiuser_V3ABv48rgT8A
Video recording playback divided into 4 quadrants, two green and two purple. Tello app has the appropriate permissions to storage as the videos and images are there, just video is bad.  Images are fine.
Interesting thing is that after noticing the video recording issue, I installed Tello FPV and video recording in it is fine. So it is the Tello app having the issue. No, I don't have another phone or OS to try it on and why should I, Android has 74% market share.
Tello
App version 1.3.0.0
Firmware version 01.04.78.01
I am using a compatible device (www ryzerobotics com/tello/downloads)
Samsung Galaxy Note 4
Model number Samsung-SM-N910A
Android version 5.0.1
2019-3-21
RYZE
Super Moderator
djiuser_V3ABv48rgT8A Posted at 3-21 02:50
Thank you for your cooperation. And we are sorry for the inconvenience that this caused.
After confimration, we found that Samsung Galaxy Note 4 is a compatible Android device. But in order to solve your problem more efficiently,we recommends you using other compatible Android device to test our Tello APP.
We have also forwarded your case to the R&D department. Could you please provide us some screenshot about the interface of playback?
We highly appreciate your kind understanding.
2019-3-22
Cabumo
Mexico
Hi! Same issue on my Moto G6 Play, with version 8.1 of Android, everything worked fine, the problem occurred when I updated to the version 9.
Firmware Version 1.04.78
App Version 1.3.0.0
Phone Motorola Lenovo G6 Play  ( XT1922-4)
Android 9.0
Regards!
2019-3-23
12Next >
