Hello there, sorry for the troubles with the Ronin-S, Yaw, Pitch and Roll are more official, please follow the steps below to make a troubleshooting first:
1. Please make sure all the knobs have been tightened.
2. Did you mount the camera mounting plate and the lens support?
3. Please try to calibrate the joystick and the system to see it works.
4. If there is no luck, please tilt the device 45°, then check if the Power value of the tilt motor is in the range of +/-5. If not, the device will need to be balanced again.
If the issue persists, please provide us the following info:
1. The model of your camera.
2. The firmware version.
3. The screenshot of the Motor Parameters especially the value of the Joint by clicking More.
