Battery drain fast
1693 9 2018-12-1
Madtownguy2
I’m noticing my battery always drains really fast.  I did an 8 min hyper lapse flight and battery was down under 40%.  Shouldn’t I be getting around 30min on a battery?
Also is there anyway to preview hyperlapse on phone.  I haven’t found an easy way to convert them yet.
2018-12-1
Koelkop
Flight distance : 22814806 ft
South Africa
How high did you fly and what was the wind like on the ground?
2018-12-2
dronybaloney
Flight distance : 24971795 ft
I read somewhere that hyperlapse eats batteries
2018-12-2
A CW
Flight distance : 14177772 ft
Fast wind speeds will massively drain the battery.
2018-12-2
hallmark007
Flight distance : 10017858 ft
Was your battery at 100%, and this will only be at 100% if voltage is at 4.25 to 4.30 , if your battery had been charged 3 days or so before it may have gone into hibernation.
2018-12-2
JAgraphics
What is the condition of the battery?
How often do you do a dull discharge and re-charge?
What was the temperature?
What was the wind like?
Was it an original DJI battery?
Lots of variables.
2018-12-2
Madtownguy2
Wind speed was minimal, I’ve never gotten anywhere near 30 min out of battery on several different days.  It’s usually 60-85 degrees in Florida. All dji batteries, I haven’t done any special way of charging other than putting them on the charger and leaving until full.
2018-12-2
saviour
Flight distance : 604203 ft
Realistically I fly around 25 minutes before landing.
2018-12-2
DJI Tony
Hi, sorry for the troubles that it caused. Do you have a spare of battery to easily isolate the issue? Are you using the drone in a recommended environment? We may need to confirm your second query to our team for further clarification. Please keep us posted for further help. Thank you for the support.
2018-12-2
flightlogicRV9
DJI Tony Posted at 12-2 13:02
Hope santa brought batteries
2018-12-18
