Armazia
Flight distance : 125069 ft
Moore-Grant Posted at 12-17 05:49
Hello All,
Yes, I have calibrated the vision system. I was just wanting to know if it either warned you, of there was a test, if the ultrasonic sensors were not working correctly?
When the vision sensors are faulty, you will get an error in the DJI App. I guess if the Ultrasonic doesn't work you would get an error aswell (haven't seen this error myself tho).
What I would do to test ultrasonic is;
1. In a quiet location hear if you can hear ticking from the bottom of the bird, does it tick? Then the ultrasonic sensor does emit.
2. Hover about 3m above ground (if you think the sensor is faulty, try above a soft ground type), then lower the drone slowly and check if it slows down when its near the ground and lands.
3. Repeat step 2 a couple of times till you can just full throttle lower the drone and it lands.
4 Try the auto land feature. Just hover again and land it auto. It should land.
If these steps succeed, the ultrasonic sensors are working fine, as they are being used for the landing sequence. |
