adp.snc
Keule Posted at 3-1 21:41
The available aircraft/camera setting contradict with DJI's statement: Only Enterprise series aircraft can be flown with Pilot app.
According to DJI's list these are: Matrice 100, 600 pro, 200 series, 200 V2 series, M2E, M2ED and P4 RTK.
Well if you try to use it with a Matrice 210. it won't recognize the camera as well. Only Phantom 4 ones are listed.
Tried with an X4S and no luck - by the way, DJI .. if you put the option for "custom cameras" which requires Sensor size width and height in mm and Focal Length in mm .. you could as well put those datas in your own cameras specifications.
I mean, you list only phantom 4 cameras in the Pilot, and that's annoying. But you also don't give the info so we can do it manually.
And by the way, on the iPad there are all those infos, only on Crystalsky they are missing ..
It's very disappointing. |
