Button in Android native app
482 4 2018-12-3
Anioet
Hello,
To the many users who complain about the impossibility of using the DJI in 4K 60FPS, you answer that we must use the native application of our smartphones. So I would like to know if it is possible to use the OM2 buttons (in particular the button that starts/stops the video) in the native application of a smartphone under android (Samsung GS9)?
Thank you.
2018-12-3
bjashton
Flight distance : 245932 ft
Filmic Pro works with the OM2 and supports the start/stop video. It might be worth checking if that supports 4K 60FPS on your device.
2018-12-4
DJI Tony
Hi, thanks for the inquiry. Apparently, you could still use the buttons on the handheld for as long as the device it's connected to Osmo mobile via bluetooth, however, we may need to confirm this to our team to see if the buttons will accurately work including the zoom functionality. Thank you for the support.
2018-12-4
Anioet
Hello,
Thank you for that answer. I don't know why, yesterday when I tried to connect the Osmo Mobile 2 to my smartphone it was detected by the Dji Go application, but on the other hand it didn't appear in my bluetooth settings, so it was impossible to connect it directly to the phone without going through DJI Go.
Today it works perfectly, I managed to connect it directly, and I can use it to make videos via the native application.
2 small details:
- the zoom buttons don't work (it doesn't matter I don't use them)
- the "video" button corresponds to the "Volume +" button on my phone, so in the application settings you have to configure the volume button so that it starts the video and not that it takes a picture
2018-12-4
DJI Tony
Anioet Posted at 12-4 16:15
Hello,
Hi, thanks for your updates. You mean, you have to configure first the settings on your camera app for you to record a video while using our Osmo mobile 2?  Yes, if you want to use the Osmo mobile 2 regardless if you will use DJI GO app or not, you have to use connect your mobile device to our Osmo mobile 2 via bluetooth. Thank you for the continued support.? Thank you for the continued support.
2018-12-5
