hallmark007
Flight distance : 9827923 ft
Yummyburger Posted at 12-6 17:24
Hi
If i am not wrong, i rth within a min of the warning. when i lost connection, my battery was 54% and at a distance of 1167.384m. have more than enough battery left. My drone is always set to return upon lost of connection, i would never set it to hoover as i always fly out to sea to avoid interference.
I think you are misunderstanding what I am saying,
Your craft goes into RTH failsafe it will not just fly straight home, it will in fact retrace the route it took to get where it last was , if it doesn’t regain signal after 60 seconds, it will then fly directly home,
So consider this your craft flys directly away from homepoint for 60 seconds plus 10 seconds hovering , because that’s were it was flying to retracing at approx 32kph plus it hovers for 10 seconds if signal doesn’t return then your craft heads for home so it will first have drained some battery plus it will now be a further 600 to a 1000 metres away so now more than 2000 metres to homepoint , this can be verified if you check last 1 minute of flying , your craft travelled over 1000 metres at approx 30 kph , and you will know what setting Critical battery was at so my guess is it never made it home but auto landed most likely in the water.
What I’m saying may not have happened, but it is what should have happened.
