Mavic 2 Range Test - Maximum Range Achieved
8730 34 2018-12-4
kykmavic
Flight distance : 5294334 ft
Cyprus
It would be nice to see some range tests with the new Mavic 2 (Pro or Zoom).
What is the maximum range (distance from the home point) that can be achieved in practice?
What is the optimum speed which enables the most economical usage of battery in order to achieve the maximum range?
Tests with documented evidences (e.g. flight records from DJI Go 4 app) will be much appreciated.
2018-12-4
Suren
Flight distance : 6923517 ft
South Africa
2018-12-4
integer
Flight distance : 55520128 ft
Greece
here is a nice flight distance test
2018-12-4
kykmavic
Cyprus
integer Posted at 12-4 07:08
here is a nice flight distance test  https://www.youtube.com/watch?v=TB7xjDTS6IM
Very impressive!!! Well done!!!
Although very risky.
2018-12-4
Sky Carrier
Flight distance : 590102 ft
India
Wow, amazing. Well done. Thanks for sharing
2018-12-4
Vendex
Flight distance : 10697411 ft
Bulgaria
2018-12-4
M Stuart K
Flight distance : 1267717 ft
Crazy and capable aircraft!
2018-12-4
DJI Stephen
Super Moderator
Hello and good day. Thank you for sharing your experiences regarding the range distance of your DJI Mavic 2 Pro and with the DJI Mavic 2 Zoom. For reference the max flight distance (no wind) is 18 km (at a consistent 50 kph) and the max flight time (no wind) is 31 minutes (at a consistent 25 kph). In addition I will be posting a link where you can find the specification of the DJI Mavic 2 Pro and the DJI Mavic 2 Zoom. Thank you for your support.
https://www.dji.com/mavic-2/info#specs
2018-12-10
A CW
Flight distance : 11526437 ft
Serious distances reached
2018-12-10
kykmavic
Cyprus
Range with Mavic 2 Pro: 9 km.
Return Battery: 16%
No mods.
2018-12-31
R&L Aerial photography
Flight distance : 298100 ft
I don’t have any proof but under ideal conditions I flew out 15000 feet the mavic was at an elevation of 400 feet high. Ideal conditions were as follows, open, elevated field , no WiFi or other interference and partly cloudy skies with very little wind....
2018-12-31
Alex B.
Flight distance : 4622680 ft
kykmavic Posted at 12-31 10:13
Return Battery: 16%
No mods.
Nice one!
Flysafely
Alex
2018-12-31
Lucas775
Flight distance : 11946043 ft
Check out my post.
https://forum.dji.com/thread-172008-1-1.html
2018-12-31
bikoo
Flight distance : 465200 ft
United Arab Emirates
2135 meter then i start to get adjust antenna so i return back.
2019-1-2
kykmavic
Cyprus
bikoo Posted at 1-2 00:42
Did you try to change from 2.4GHz to 5.8GHz or vicce-versa?
2019-1-2
SPIKE_151
Flight distance : 69767 ft
I have just bought the Titan 3w boosted switch antenna for the Mavic 2 pro so I shall be posting up here soon on what distance I get compared to the rather bad CE mode stock, which is about 2 km tops before losing signal.
2019-1-2
bikoo
kykmavic Posted at 1-2 03:36
no , it was on auto
2019-1-2
photographermarbella
Flight distance : 6280 ft
Hi, mine starts to lose signal at 1.8Km which is pretty rubbish. Is there any benefit to 2.4GHz or 5.8GHz? Could it be power lines? anyone flying near a city or powerlines?
2019-1-2
kykmavic
Cyprus
photographermarbella Posted at 1-2 12:42
I suggest to try another location and see if there is any difference. There may be a strong interference where you are now.
2019-1-2
Alex B.
Try along the beach or out to sea, that way the interference is minimal.
I got 6300 meters one way along the beach with my mavic pro
Flysafely
Alex
2019-1-2
That is out to sea, I live in Marbella on the costa del sol.
2019-1-2
Alex B.
photographermarbella Posted at 1-2 12:55
Yes, I know, I saw your profile name.
I used to live in Marbella for 8/9 years myself before
Well what can I say, it sucks only 1.8km, but still I would try in a different place or to be sure, several places. If it doesn’t improve, I would try maybe on another device.
And if that doesn’t change anything, then I would wait for the CE to FCC switch for the mavic 2
On FCC you can fly the 8km that is advertised, CE mode is always much worse on DJI drones
Flysafely
Alex
2019-1-2
Lolo780
Flight distance : 33953406 ft
2019-1-3
Alex B.
Amazing! That’s some balls!
Flysafely
Alex
2019-1-3
kykmavic
Cyprus
Lolo780 Posted at 1-3 00:09
https://youtu.be/1VEx7wcM0QQ
Awesome! Impressive!
From your video someone can learn a lot. Surprise how you managed to return the last km with 0% battery. Also the cell voltage was about 3.4V while the percentage was at 0%.
By the way can you explain the two white lines shown in the photo below, was it actual a path flown before?
2019-1-3
Lolo780
The M2 battery meter is very conservative and the 4s power system will happily fly down to 3.4v/cell.  At 3.3v there's about 30 seconds left.  For anyone worried about battery life, I have over 90 cycles on one pack and it's still going strong.
White lines are the previous flight for testing wind conditions.
2019-1-24
SPIKE_151
Yes there is, from the manual, the power transmission for CE or FCC mode is greater at 2.4 ghz than at 5.8 ghz, so for distance alone, if there were no interference on either frequency, 2.4 ghz should give you greater range. Nearly all the boosted range extenders that are amplified you can buy from third parties work only in 2.4 ghz.
2019-1-28
raven swe
Flight distance : 472500 ft
Sweden
Mavic 2 Zoom 5Km across a lake in CE mode, could have gone a bit more but that was enough for me, 1.5Km in heavy wooded area.
2019-1-28
Alex B. Posted at 1-2 13:07
Hi Captain Alex, I'm running the mavic on an android Samsung S9+. I don't understand CE or FCC, I see there is a choice of transmission frequencies and that there appears to be a difference in allowed distance between the USA and the rest of the world but how is it possible for such major differences between people distance experiences? If there are restrictions should DJI not claim 7Km as the available distance?
2019-1-29
SPIKE_151
photographermarbella Posted at 1-29 03:04
The power available for transmission between FCC ( USA ) and CE ( Europe ) is based on what those areas deem safe for radiation. The USA is less bothered at the amount of radiation given off by the controller.
The different distances are affected by a whole raft of different circumstances, including but not limited to, battery drain due to speed of the drone, background radiation from wifi routers which transmit on the same frequencies that drone controllers do, weather, humid conditions will absorb transmissions from your controller to some extent, interference from water surfaces scattering signals from your controller. As you can see there are probably 20 or so more things that can affect your range on top of the ones Ive noted.
2019-1-29
fans21618e60
Flight distance : 4341640 ft
SPIKE_151 Posted at 1-29 04:19
I had my Zoom out 32,00 ft, a little over 6 miles or about 10 km one way and made it back with 5% battery. It will go over the 18km that they state.
2019-4-29
3BEPb
Flight distance : 165928 ft
Good to see people are pushing their drones!
Surprised none of “what if” trolls posted with their VLOS crap
2019-4-29
GregLinhares
Flight distance : 19383 ft
integer Posted at 2018-12-4 07:08
WOW!!! That was AMAZING!!! Thank you!
2019-5-5
fanseb83622d
Slovakia
hi how it works with that range FCC and CE? Does it automaticaly swich FCC model to CE while in europe and vice verse CE uerope flying in USA to FCC in regards of range?
2019-7-12
parkgt214
Flight distance : 971677 ft
3BEPb Posted at 4-29 12:55
Considering the new FAA rules for Recreational fliers.  It probably is not a good idea to post such tests if flown in USA.
Of course having a VO with constant eyes on the bird and instant communication would make it legal.
Doing these in remote uninhabited places doesn't pose much if any risk.
2019-7-12
