Yaw Error
448 2 2018-12-4
Kevin Halle
Flight distance : 1297612 ft
H02m 29s222.8 ft947 ftMode[url=]Mode changed to Atti[/url]
I02m 29s222.8 ft947 ftWarning[url=]Yaw Error. Warning:Compass Error. Exit P-GPS Mode[/url]
J02m 29s222.8 ft942 ftWarning[url=]Yaw Error (repeated 12 times)[/url]
Can anyone give me some insight as to what would cause this error? Inspire 1 v2
Here is the flight log:  http://www.phantomhelp.com/LogViewer/ZWW1VP4NU8PRUFODF4D5/
Thanks in advance
2018-12-4
Henry M.Y.
Flight distance : 11548839 ft
Hi Kevin,
It looks like you encountered intermittent magnetic interference at 2m29.3s into your flight, leading to unreliable compass readings which your Inspire 1 decided to ignore them, and record the subsequent 1.3 second of flight as "Yaw Error". Not 100% sure though.
From the log, I can see the Inspire 1 was still precisely responding to your stick inputs in ATTI mode. No need to worry too much if it does not happen again.
My 2 cents.
Henry
2018-12-8
Kevin Halle
Henry M.Y. Posted at 12-8 03:51
Hi Kevin,
Thank you Henry. Your response makes sense to me.  I was kind of thinking the same. Others have responded as well basically the same. Like I said earlier, I recalibrated the IMU and compass and the issue hasn’t occurred since.  There were also several battery errors in that flight and I’ve returned that battery in exchange for a new one. I have no idea if that had anything to do with it but I was not going to risk it.  Thank you again
2018-12-8
