DJ1 Assistant 2 and vision sensor calibration
785 4 2018-12-5
MXGIRL_75
I've tried twice now, get all the way through to where it is supposed to load the calibration and it sits at 0%, never loads the calibration
2018-12-5
DJI Stephen
Hello and good day MXGIRL_7. I am sorry to know that you are having issues in calibrating the vision sensor of your DJI Mavic 2 Pro. Did anything happen on your previous flight, like hard landing or crash? Is the firmware of the drone up to date? If not, please upgrade the firmware, then try it again. I will be providing you the link where you can find the latest firmware of the DJI Mavic 2 Pro. Thank you.
https://www.dji.com/mavic-2/info#downloads
2018-12-5
MXGIRL_75
DJI Stephen Posted at 12-5 10:22
According to the DJ1 Assistant 2 and when I first connected the Mavic to the RC control, it wanted to update the firmware which it successfully. The Asstant verifies that the firmware is up to date.
I have not gotten to fly the drone yet. I live close to an airport and is all I get when I try to even fly 5 ft off the ground, I am in a NFZ and will not even start the props..  I can't find anyplace local to me to fly and the wind has been blowing to much to fly anyway.. I was just trying to calibrate it... Maybe it does not need it?
2018-12-5
DJI Stephen
Thank you for the reply. There will be a notification if you need to calibrate the drone. For reference I will also post an official DJI tutorial video on how to properly calibrate the vision sensor of the DJI Mavic 2 Pro. As for the NFZ, you can use this link to check and to temporarily unlock a NFZ area https://www.dji.com/flysafe/self-unlock. I hope this can help you. Thank you.
2018-12-5
Hani
Flight distance : 1392995 ft
I have the same issue. I refreshed the firmware and did the sensor calibration several times, but it gets stuck on 0%.
2018-12-6
