Awesome22Ana
Flight distance : 19587 ft
Geebax Posted at 12-6 14:01
Many types of prop guards are sold with extra long screws to attach them. When you remove them, you must put back the OLD screws, not the new ones. If you use the longer screws, the tips of them dig into the windings on the motor, and the motor is then stuffed.
Thanks for the recommendation, I did unscrew the screws to see if I had used the longer screws and it looks like I used the correct screws(the shorter ones). The only other thing I can think of is maybe I used the longer screws earlier, which may have damaged the motor. But it's suspicious to me because it's only on one motor |
